Removing Schneider/ merlin geran Circuit breakers from panel board busbar | on ElectriciansForums
Discuss Removing Schneider/ merlin geran Circuit breakers from panel board busbar in the Talk Electrician area at ElectriciansForums.net
T
timmy123
Hi
I am replacing 2 circuit breakers in a Schneider panel board. Board is 3 phase and main switch is Schneider NSX 100. Circuit breakers are Schneider NS100N compact series. Replacing 30 amp breakers with 63 amp identical units. The breakers are single phase units.
my problem is that I am having difficulty removing the breakers from the panel board busbar. The obvious screws have all been undone but the breakers are not shifting.
I have spoken to Schneider technical but still awaiting a reply after a week.
i would appreciate any advice. I have photos but not sure how to attach to this thread.
many thanks.
Reply to Removing Schneider/ merlin geran Circuit breakers from panel board busbar in the Talk Electrician area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
All socket outlets up to and including 32A (which are commercial, not domestic) are required to be 30mA RCD protected. By the sounds of it you...
