Renewing consumer unit - no space | on ElectriciansForums
Discuss Renewing consumer unit - no space in the UK Electrical Forum area at ElectriciansForums.net
Berkshire
Hi.
An electrician isn't my day job but I qualified on one of those 'quickie' courses a couple of years ago, thus I am competent yet rusty on some aspects.
My conundrum is that a consumer unit needs upgrading. However, the CU is situated in a low cupboard on a narrow (right hand) wall, it just fits and awkward to get to.
A new (amendment) CU is obviously much larger, but would fit comfortably on the adjacent wall some 40cm away.
My question please, to the venerable, is: Would it be acceptable to replace the old CU with a junction box housing, and to run the various twin & earth cables from here to the new CU nearby?
Many thanks for (polite) replies!
Providing you used the correct enclosure/connectors, and the install was up to current standards, and the DNO was prepared to move the supply to the new proposed position, and if the cost of moving the DNOs equipment was cost prohibited, and you used the correct install method and equipment for the supply from the existing head to the new CU position, I see no reason why not.
Similar to this...(not my job BTW). I don't think the DNO equipment needs moving as it's only being moved 400mm and no distribution circuit. Looks like the OP is moving the position as a new amm3 style box won't fit in the existing space.
[ElectriciansForums.net] Renewing consumer unit - no space
What you are suggesting is an option, but I would avoid having to extend the tails in said enclosure .........
The last time I did something like this, I used a Henley block next to the old board for the tails and an external met next to the Henley...
Just a note, if you do use din rail connections. Connect the CPCs in normal din rail connectors NOT the earth ones as shown, as this will effectively connect all the CPCs together across the Din rail and make testing difficult if disconnecting at the DB terminals
Whow, thank you Vortigern for your swift reply and thank you all for your replies, love the photo Leesparky, helps a lot.
Yep, no need to move the DNO because, unlike the photo the new CU will be at the same horizontal level as the old one, (or 'head' as it will become,) but on the adjacent wall and so will become actually slightly closer to the DNO equipment. However, it does mean that I will need to run the extended cables externally between the units. (Just wish it was at head height and not under a low cupboard!)
Nice thought Wilko about using RCBOs I'll have a scratch of the head and get my tape measure out.
- and take a gander at the various types of din rail connectors.
Thank you all again.
If you are going to get a new CU how about installing an isolator after the meter?
Reply to Renewing consumer unit - no space in the UK Electrical Forum area at ElectriciansForums.net
IMO Better to do something about those ignoring regulations first! Current system is like having a speed limit but not enforcing anyone without a...
