Rental Property Regs for CCU | Page 2 | on ElectriciansForums
Discuss Rental Property Regs for CCU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just do a proper EICR and submit out with your invoice ......
What exactly is the problem, just turn off the main switch on the fuse board
As soon as the Sparky closes the door on his way switch will be back in the on postion, cut the seal and pull the fuse, how dare you Pet999 go stand in the naughty corner,
the missing shrouds on the incomer, the incoming tails terminations, would each be a C2 in my book, and the rat nest a C3.
Based on purely what you have said in the op - no.
Have you found a Reg to state that no live parts can be under the cover of a DB that is secured by screws?
How do you carry out live tests if this DB is worrying you?
The fire officer may have something to say if it is an HMO, however he is likely to say that the cu must be in a fireproof enclosure as a minimum and may not say that you need an ammendment 3 board.
Isn't the point of a cu to house live parts? As long as a tool is required to access I can't see more than a C3. Maybe able to C2 the incoming tail if it has been 'trimmed' as it looks like in the photo
If you're worried about the exposed live parts on the supply side of the main switch, just stick a few layers of tape over them while testing to reduce the chance of accidental contact. Better still, pull the fuse. After all, it'll probably need pulling later to tidy up the terminations or replace the board.
In the process of doing an EICR for a rental property (probably an HMO).
Really old CCU that has exposed live parts once the lid is removed and so would need to be super careful testing as there is no other isolation except the 100A tagged fuse.
Don’t feel comfortable doing any further tests because of the safety nature (am I a wimp).
But it occurred to me that surely this should definately be a new board upgrade job if it’s in a HMO property?
Thoughts??
Do you wear womens clothes and run frantically when a lorry drives over speed bumps?
Reply to Rental Property Regs for CCU in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
