replaceing consumer unit in shed (with no earth) | on ElectriciansForums
Discuss replaceing consumer unit in shed (with no earth) in the Australia area at ElectriciansForums.net
A
Avidude
hi i am looking to take my napit exam.
i want to replace a garage consumer unit,
i have looked and found that it is using the swa as the earth (2 core swa)
what can i do?
can i use the swa as the earth for the new consumer unit?
i don't want to have to use a TT system.
thanks for any input
avidude
what size SWA. and can you get a Ze reading from the garage end? might be better to make sure the SWA armour is earthed at the house end only, then TT the garage. That way you will only be assessed on your work in the garage. be sure to RCD/RCBO both circuits.
Hello
the swa is only 2.5 2 core,
i fond that the swa was not even connected at the board (So there was no earth)
i have never worked with tt system before.
where can i find out where to buy and how to use earth rods?
any wholesaler will sell you a rod and clamp for about ÂŁ10, just knock the rod into the ground fit the clamp on the end and tie your earth to it.
alternatively run a seperate earth from the met to the garage (exporting of earths may or may not be an issue)
As it's a TN-S system, using the armour as the CPC is totally acceptable.
Make the SWA a 20A radial circuit from the house CU and install a garage CU at the garage end. Most likely it will come with a 40A 30mA RCD, & 1 x 16A & 1 x 6A MCB's.
Make sure the SWA is glanded correctly at both ends and there wont be an issue.
as both previous posts. earth rod,(missing drains etc) drill concrete floor, whack it in, no aggro with exsported earth, connection in proper box and flagged with safety earth blah, blah tag., 10mm G/Y in pvc tube to CU. nice job.
This is what i'd be doing too.
Reply to replaceing consumer unit in shed (with no earth) in the Australia area at ElectriciansForums.net
I hate it when a shed is TTd, why can they not be extended from the tn system? popcorn ready
2 3
