OP
LeBlur
a like for like replacement just needs to be similar fan. does not have to be the same make/model. as such, no paperwork is required. adding a pull cord would be modifying the circuit and a minor works certificate completed by a competent person. strictly speaking this would be notifiable and a RCD fitted if not already in situ for the circuit.
So, (almost got my head around all this) if I went with the Greenwood Airvac RF90, just using the inbuilt humidistat (as is now), the fan could just be swapped over and job done. No notification required. No paperwork required. Not even an
Electrical Installation Certificate?
If I added a pull cord, for manual control as desired, then notification and certification required. Also an RCD would need to be fitted.
As the fan looks like it is presently fed via a fused link into the lighting circuit in the loft, will a new feed down to the fuse box be needed for this?
Looking at the suggested in-line fan up in the loft option….this would either need control from the bathroom light switch or from another pull cord, or even a separate humidistat unit. As all these options would be ‘modifying the circuit’ I presume they would require notification/certification?
