This is an RSS feed of thread: Replacement Diverter valve for obsolete tap
Content of the thread: Hi,
I have a Bristan Matrix Bath Shower Mixer Tap, the diverter valve has been temperamental for some time and has finally failed with a split rubber washer. The tap is obsolete and spares are no longer available.
(I have contacted Bristan.)
The bath is built in and access to the tap is not possible without a lot of dismantling.
Does anyone recognise the washer, (dimensions are approximately 25mm dia by 10mm thick at widest point)?
Vado have a matrix tap that looks very similar to the Bristan; is there a chance that the diverter valve is the same?
Jim
Replacement Diverter valve for obsolete tap to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Jim
