Replacement of CU in TT system | on ElectriciansForums
Discuss Replacement of CU in TT system in the Australia area at ElectriciansForums.net
A
austin
Hi Guys
i am about to change a CU on a TT system. IT has re-wireable fuses and is fed from a 100mA RCD (pretty standard) I am planning to change it for a split 30mA rcd board. Can I leave the 100mA rcd in place and use it like an isolation switch for the CU or will it cause problems.
Cheers
Hi Guys
Cheers
Replace it with an S-type for discrimination.
Reply to Replacement of CU in TT system in the Australia area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
Many thanks all. Very helpful to be able to bounce these things around. Was fairly happy with it all initially, but once the seed of doubt is...
