Replacement of main switchboard | on ElectriciansForums
Discuss Replacement of main switchboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
SkildJanitor
When is it necessary (under 17th edition regulations) to replace an existing switchboard with a new one?
e.g if the existing board has only got rewirable fuses with no rcds or mcbs and i want to split the tails and connect a new sub board, do i have to upgrade the existing board to mcbs and install rcds? or can i just leave it as it is?
Cheers in advance
you can split tails and leave old board as is. just your new board and it's associated circuits must be done to current regs. i.e RCD where necessary, Correct size cable, MCBs etc.
edit. you must, of course ensure earthing and bonding are compliant with current regs'
Thats excellent. I was aware of the testing of main bonding. I just wanted to avoid having to replace old consumer units if there wasnt a spare way available, instead, split off a heney block and put my new board in.
Appreciate your help
Reply to Replacement of main switchboard in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, Great to of found this forum. Much respect for keeping everyone safe! My background is in commercial data and Audio Visual. Been...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
