iantresman
I'm replacing our oven, and want to make sure the new oven does not exceed the power requirements of the old one, but I can't find it. Our existing EOS66SS2 shows only the following information:
Nominal voltage 220V - 240V ~50Hz
Power connection: 13 A automatic bipolar switch with protected socket
Power absorption:
Does this indicate the maximum power is 1.35kW, or should I combine them to show 3.55kW, or has this nothing to do with the power?
Power absorption:
- Base Resistance: 1.30 kW
- Roof Resistance: 0.90 kW
- Grill Resistance: 1.35 kW
