Replacement panels for a defunct manufacturer
The only 'generating capacity' that gets registered on the CFR is the TIC and DNC - I can't see that there is any other 'generating capacity' that they could be referring to. This is what 8.13 means.
I also can't imagine that OFGEM are suddenly going to start behaving reasonably, although I would love to be proved wrong on that.
as I say, this could be something that MCS could do with issuing a technical briefing / statement on - they were the organisation that OFgem worked with to release guidelines for TIC definition, but until that point I'm going to go with the interpretation that if it doesn't actually result in any increase in either annual or peak generation, then it's not an increase in the generating capacity of the system.
(ps can someone remind me about this and I'll try to get it added to the MCS agenda for the next meeting)
