Status
Not open for further replies.
I read once, never seen one for sale, that there is a solid brass replacement for the standard 13A fuse in a 13A plug. This is to eliminate the fusing in the plug, which is handy when having a heavy appliance plugged in behind itself, like under worktops which are isolated and fused by an FCU.
Anyone know where they are available, if they are?
On a dedicated radial with its own MCB and say a 20A isolator switch a washing machine can have a 15A fuseless round pin socket and plug. That is fine, but many manufacturers say that if you remove the 13A moulded plug the guarantee is void. This would never hold up court if an appliance is connected to regulation being sound and safe, but it is avoiding the hassle factor from these irresponsible makers.
So there!
You can get a solid fuse replacement in other sizes, mostly much larger, though I did notice a 20x5mm size:
"A solid fuse replacement slug, 5x20mm used to remove/replace a fuse terminal fuse with a straight-through option. Solid links can be used when trying to trace a fault in part of the electrical system."
Haven't seen any in BS1363 size.
Status
