replacing a consumer unit | Page 2 | on ElectriciansForums
Discuss replacing a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
David Say
I have read various conflicting documents about updating fix equipment and really like know the correct answer to my problem. A Consumer unit in an existing property is 450mm from floor level, now I know there is no height set for consumer units but if i change it can I leave I there or will I have to move it
In my handy Pocket Guide 7 it sugests that sockets switches and other electrical equipment should be between 450 mm to 1200mm. So its more like between Nuts and Knees :)
nah. knees and navel.
That's correct of general switches and accessories, but the current part M requires consumer unit switch devices to be at 1350mm - 1450mm above floor level.
got blue ---- and great ----. all about 3" in length. it's the pigeons that cause problems. next door's cat gets to them after i shoot them.
So they decided that they did not care about disabled people accessing there Consumer unit to reset an mcb or rcd when a lamp blows
I suppose it must be deemed accessible to wheelchair users yet out of reach of small children. It's the primordial dwarfs I feel are excluded here.
Falling objects is what I was told on the 2391.
I can vouch that. Did a job recently, where the old chap kept all his small cartridge fuses for his Wylex board on top of it, for safe keeping. He kept losing them though. I took the lid off and found them all on top the main switch terminals, haven fallen through an non compliant IP rated hole :-(
The new board can stay at the same height the old one is. The new board shouldn't be installed at a new height which would make it worse for accessibility than it is now, which in your case would be below 450mm.
Reply to replacing a consumer unit in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Yep, that’s what I do. That spare RCD has always come in handy down the line.
