Replacing a Crabtree Starbreaker B32 RCBO 30mA Circuit Breaker Old Type | on ElectriciansForums
Discuss Replacing a Crabtree Starbreaker B32 RCBO 30mA Circuit Breaker Old Type in the DIY Electrical Advice area at ElectriciansForums.net
Nicovid
Swindon
Hi, I need to replace a Crabtree Starbreaker B32 RCBO 30mA CIRCUIT BREAKER. 61/B3230 old type which is now obsolete and can only be bought online from Ebay.
Comapring the image of the breaker online, there is a small difference to the one that needs replacing. Printed above 30mA is a square box which has 2 squiggly lines
within the box. The image on Ebay, there is only 1 squiggly line. What does the squiggly lines refer to ? Would it be possible to replace the breaker with
2 squiggly lines with the breaker with 1 squiggly line. If not, what are the options open to me, is there an equivalent breaker out there to replace this old type, or would I have to replace and install a new consumer box.
I will be getting an electricion to do this work I just wanted advice on the options before calling an electrician.
Many Thanks in advance.
Paul N.[ElectriciansForums.net] Replacing a Crabtree Starbreaker B32 RCBO 30mA Circuit Breaker Old Type[ElectriciansForums.net] Replacing a Crabtree Starbreaker B32 RCBO 30mA Circuit Breaker Old Type
A modern Starbreaker should fit. It will be only one module wide whereas yours is two module. Make sure they get the compact version. I can't put up a link but Google Starbreaker 32A compact rcbo.
Thank you so much.
Regards,
Paul N.
Reply to Replacing a Crabtree Starbreaker B32 RCBO 30mA Circuit Breaker Old Type in the DIY Electrical Advice area at ElectriciansForums.net
Good luck with your project and welcome to the forum
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
7K
suffolkspark
