replacing a dimmer light switch with a regular one | on ElectriciansForums
Discuss replacing a dimmer light switch with a regular one in the DIY Electrical Advice area at ElectriciansForums.net
jennliner
South Carolina
Hello, I am trying to replace a non-working dimmer light switch with a regular single light switch. Did I do it right? I put the wires in the same place they were on the dimmer switch, but I don't know what the white wire is for. This is for a ceiling fan with a light kit. Blue switch on the left is the new one for the light. Switch on the right is for the fan and works fine. I thought this would be easy, but there are so many wires.
[ElectriciansForums.net] replacing a dimmer light switch with a regular one
This is the old dimmer switch if that helps.
Are you sure it was connected?
Does the light work?
Honestly just install a wire nut on it and put it back in the box. It serves no other purpose.
Reply to replacing a dimmer light switch with a regular one in the DIY Electrical Advice area at ElectriciansForums.net
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
Figured things out. Thanks for the help. Original wiring only had one wire going to the bottom of the left switch. Found some spare wire and...
