Replacing a Socket the 4 Homes way
P
Phil
No mention of any safe isolation, no mention of a volt meter never mind an approved voltage indicator if you want its full title anywhere in the tool list,
Socket back box and faceplate
Cold chisel
Plaster filler
Hammer
Hammer drill and masonry bit (12-18mm)
Electrical screwdriver
Pliers
Wire strippers or craft knife
Gloves
Goggles
Pencil
Spirit level
oh and on the tip list it says to get it signed off by an electrician when you have finished;
finished what? having a cardiac on the floor because you did not check it was safe to work on
I tried to read it but it doesnt open fully :( wonder if complaints have been flowing ) I have also Emailed and told them to check with EICNIC NAPIT ect ect ect and NOT Joe down the pub who it sounds like they have asked
Check out the dimmer switch advice!! Showing a picture of a board with mcb's it then advises to remove the fuse? But thats ok because you've put up a sign asking people not to switch it on because you're working on it!
It says cut back 20mm of outer insulation - WTF. that would be showing lots of bare copper!
I normally only go back 12mm by eye!
whats `outer insulation`?...if you mean the grey....thats not classed as insulation....its there to protect the insulation underneath......and i also generally make off about 30mm of insulation.....then double over the conductor to give 15mm.....unless its a spur off an existing socket of course....then i just make it off 15mm.....
Pretty clever programme planning if you ask me.
Step 1 :Encourage people to fart about in their houses carrying out tasks they haven't got a clue about using duff info.
Step 2 : Locate said people and film new series of homes from hell/diy sos/do my house up for nowt please/can you fix my shoddy work which I should never have attempted in the 1st place.
Genius
Never mind the minor details of 'how to do it', I'm slightly concerned about WHY someone would use this information - changing a single socket for a double where the (presumably qualified) original designer of the installation has elected to install a single socket rather than a double.
This may have been to restrict the number of flexes coming from the socket, eg for only occasional use of a vacuum cleaner in a hallway rather than running flexes across or around doorways,
or to restrict the amount of current that can be drawn from one point, such as with a switched fused socket for a specific appliance, or even a 2A round pin lighting socket.
eccept it wouldnt restrict the number of flexes Adam.....all it will do is encourage the use of those unfused boxes with 3 outlets on em.......and i think they should be banned from sale myself......
The single sockets are pretty common in houses wired in the 80's a before it. Another common single socket is Economy 7 storage heaters removed when central heating put in and the old electrical point changed for a single socket.
A few years ago I did a year as a volunteer with my local fire service,and was shocked to learn that most house fires are caused by 2 things,candles and double adapters I remember being told at the time that something like75% of domestic electrical fires were caused by using adapters,in the modern age they should be outlawed,I make a point of telling people about the fire risk associated with them and the fact that it,s not only the amount of plugs but also the strain placed on the contact tubes in the host socket,which weakens them and leads to arcing.
Iv mentioned before about the display case that use to be at glasgow transport musem it was part of a fire brigade display had one lump of what looked like 8 or 9 adaptors in a row aall nicely melted it also had my fav thing for unplugging a ROOLED up extension lead well Im assuming thats what it was as it was just a circular lump of mushed stuff joe public will be Joe public and people working in shops offices ect ect WILL no matter how many times thery are told not to Overload sockets ,daisy chain 4gang extensions ect ect ( I saw a 13a 4 way plug other night while in BnQ Even my wife said" WHY would you use that coz theres only 1 fuse if it went everything would go"
If someone's got an adaptor why would they plug it into the hallway and run cables through doorways when they could use the adaptor closer to where they need it?
I was under the impression they had been banned, or at least no longer conform to British Standards, but that won't remove them all from circulation.
When I was a kid the danger of overloading sockets was fairly widely publicised with pictures of multi-way adaptors plugged into a single socket, but here we have channel 4 telling people to change single sockets for doubles with no mention of considering the cable supplying them. Remember changing 2 single sockets for a double allows the same additional current to be drawn as an unfused 3 way adaptor, the difference is the 3 way adaptors have been widely discouraged.
Also as I mentioned this could include someone changing the single 2A lighting sockets for double 13A sockets, or changing that 2 way light switch which they rarely used and 'converted' to a socket into a double socket.
Whichever way you look at it a single 13A socket is limited to 13A, whereas a double one is, well, doubled, to 26A.
I'm not saying there is anything wrong with double sockets, but the circuit has to have been designed for them, which the channel 4 website doesn't mention.
Phil,
AP Electrical,
