Hi, would really appreciate some thoughts on this. Customer has asked me to change all 40 downlights in his flat (yes, 40) from ELV halogen to LED. Some transformers had failed so agreed to change over to GU10. I said I could either change the lamp holders and keep the existing fittings or replace them altogether. He decided on the latter without even questioning the cost. Fitting the new fire rated lights involves enlarging the ceiling cut outs slightly and removing the transformers from the wiring.
If I was only doing a few I'd charge similar price to that for installing new downlights, but as there's so many in this case and they're almost straight swaps other than described above, don't know if he'll think I'm taking the mick. Never had to change so many in one go, wondered what others would consider charging. Lights were 9.50 each excluding bulb.
