A
alanmckenzie
Bit of a question here regarding fitting downlights in my hall ceiling. I want to fit one downlight in place of each of the three lights already there. When I remove each existing light fitting from the ceiling, they each unplug from a junction box screwed to the ceiling. Going into each junction box, from the big grey cable in the ceiling are the live, neutral and earth wires. This is all fine, but the terminal block inside the connection box attached to my new down lights only have two terminals, live, and neutral. So what do I do with the earth wire from the ceiling? The new lights are double insulated and so I believe they may not need the earth connection? But if this is the case, again, what do I do with the wire?
alan
alan
