Discuss Replacing LED chip on ceiling light. in the DIY Electrical Advice area at ElectriciansForums.net
I have bought new chips as per photo. Does it need to be held in place with insulating glue, and should I solder between the bare areas as per the old one not removed yet? Thanks for any help.
Nearly Esteemed
Supporter
I would imagine "heat sink compound" or "thermal paste", not glue. E.g:
uk.rs-online.com
Reply to Replacing LED chip on ceiling light. in the DIY Electrical Advice area at ElectriciansForums.net
Assuming the electrician checked the new driver was capable of supplying current (in other words it provided an output voltage and curent when...
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
