Replacing main switch with RCD... | on ElectriciansForums
Discuss Replacing main switch with RCD... in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Just wondered how acceptable this would be...
Need a couple of extra ways on a consumer unit.
Seeing as it's fitted with 2 RCDs (DP and rated the same as the main switch) is it acceptable to simply remove the switch and feed the first RCD from the tails?
no, because you would then not have a single isolator for the whole installation, or you would have 2 RCDs in series, depending how you configured the DB.
you could remove 1 RCD completely and replace it's set of MCBs with RCBOs. that will give you 2 spare ways. might be cheaper to fit a bigger Dual RCD board though.
Reply to Replacing main switch with RCD... in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Joining the ends of the radials together to form a ring, and changing the circuit protection to a single 32A would solve the MCB overload problem...
