Replacing Mcb in cu | Page 2 | on ElectriciansForums
Discuss Replacing Mcb in cu in the UK Electrical Forum area at ElectriciansForums.net
W
Whittler1507
Hi Newbie here hope this question is not too stupid,
I had a new CU fitted in to my garage workshop to put a 16 amp supply to my bandsaw.
This consisted of new cu with a single spur to the 16amp socket.
Said bandsaw has died and is to be replaced with another that needs to be on a 20 amp circuit. This is because of the current/amperage draw needed during start up and braking.
Which I think means replacing the Mcb with one rated for 20 amps.
The sockets are the blue bayonet type connectors which I think can take it, the cabling is 2.5mm which Runs from socket to cu a distance of approx 5m and think it can take it, am I correct in thinking that I can just get the Mcb replaced?
Also would this require another certificate/sign off?
Many thanks
Sent from my iPad using Tapatalk
I would generally prefer to see a 16A device on it but a 20A isn't actually prohibited. I think Guidance Note 1 may even mention the arrangement.
Usually it would only be done where the load profile is known.
It was specifically permitted to have a radial of multiple 16A outlets on a 20A mcb in the 16th edition, but that was removed when the 17th came out.
But even so it is multiple 16A sockets on a radial which can logically be protected by a 20A mcb, a single 16A socket has no logical reason for it
Reply to Replacing Mcb in cu in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
