Replacing old doorbell with no chime in sight | on ElectriciansForums
Discuss Replacing old doorbell with no chime in sight in the UK Electrical Forum area at ElectriciansForums.net
Miguel_92
England
I got given a ring doorbell (hardwired) and an Amazon echo as it was part of a bundle. In my house i can't see any chime box at all, but after taking the old button off the wires once again look utterly ancient/super flimsy. I think they are also dead, because i wrapped them round the 2 screws on the back of the bell and nothing happened. Shall i get a multimeter to test them? And what shall i do if they are in fact dead? Thanks.
P.S I would be using the echo as my chime once i got it working.
There seems to be a decent level of complexity to ring doorbell installation, I was just looking it up
I would say with your uncertainty over the wiring you should hire an electrician with experience of fitting these
I believe it can still be installed if you lack a chime box, but only if you've got an Amazon Echo device like me as that can be the chime. But if you've got a chime box i think you use the wires to bypass the old bell (the ones that come with the ring one) and it works, but i don't need that.
They are massively brittle and i've never seen wires this weak in my life. Because when i first tried to bend one around the screws on the bell the end of the wire snapped off.
  • [ElectriciansForums.net] Replacing old doorbell with no chime in sight
That is just standard single strand twin bell wire, as supplied with the likes of Friedland door bell kits in the past.
Or available in Wilkos etc.
How can i use my ring bell with it? Or isn't it possible? Because the old bell button was full of gunk/a bit rusty too. As i'd obviously rather use my Ring bell with the echo because it's brand new.
The wires have veeery little give in them to be honest. Even breathing on them just makes them snap, so i can't fiddle/adjust the wires very much at all.
Your better off getting a suitable transformer for the ring door bell and plug that in , the voltage of our old bell transformers are bit low anyway and need addition components to work correctly
Sorry for the late reply but that's what i did. Had to drill a hole in the door frame and it works fine. The old wires had been cut, as i could see them under the floorboards under the fuse box.
Reply to Replacing old doorbell with no chime in sight in the UK Electrical Forum area at ElectriciansForums.net
That seems a very good shout. I’ll test that
Second Update: 12/25/2023 Hey everyone, so I solved my doorbell issue. Turns out there were two reasons why my doorbell wasn't turning on. 1.)...
Great information here !
8K
I finally had some time to look at this some more. I am happy to report that all is working now. I took a closer look at the chime and it...
8K
