Replacing old double light switch with new, odd wiring? | Page 2 | on ElectriciansForums
Discuss Replacing old double light switch with new, odd wiring? in the UK Electrical Forum area at ElectriciansForums.net
Lincolnshire
Simple back story..
We have a double switch for our bathroom that controls the extractor fan (left switch of 2) and the bathroom lights (right switch of 2). We need to replace it as its bust basically.
Anyway i buy a Double 2 Way switch to replace it (picture below)
Anyway i take off the cover and are met with this...
[ElectriciansForums.net] Replacing old double light switch with new, odd wiring?
NO blue or brown, only seems to be 1 gang even though its a 2 button switch....
Taken off...
So 2 red wires seem to be going into the top right 2 and the bottom middle 2 with the other red wire going into the top left common as well.
The earth and i’m assuming neutral are not even connected to the switch.
Now i suppose the simple question is can i use the above wiring in my new 10Amp Double 2 Way switch and if not what type of switch should i be after..?
Or is it a case of simply swapping over the numbers from the old switch to the new however, on the new switch which of the common would have the 2 wires in?
Thank you for any help :)
Reply to Replacing old double light switch with new, odd wiring? in the UK Electrical Forum area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
Ah yes my apologies, thank you much appreciated.
