replacing oven and hob | on ElectriciansForums
Discuss replacing oven and hob in the UK Electrical Forum area at ElectriciansForums.net
E
easytiger
my new oven needs hardwiring but all there is in oven housing is a cooker outlet which 6kw hob is wired to and a single socket wired off this for plug in oven am i right in changing the front of socket to a DOUBLE POLE SWITCHED
FUSE SPUR OUTLET cu as 32a mcb also 45amp ccu on wall in kitchen
should be OK on a 13A FCU then. 1 point. the rating of the cooker isolator is irrelevant. the 45A is just it's max. load. make sure you use a decent FCU , not cheapo rubbish.
Reply to replacing oven and hob in the UK Electrical Forum area at ElectriciansForums.net
First thing to say is that it's desirable to have a method of isolation for the oven somewhere near it in the kitchen, and not hidden behind a...
Thank you for fast response. The reason I asked is because I had read elsewhere online: "Electric ovens have a wattage rating that tells you how...
