Hi I'm replacing a pair of wall lights, which currently have two lights per wall light for two single ones. Currently there are two live, two neutral and an earth going into each light.
New LED light just has one live one neutral and a sleeved entry cable to for the house wires. States specifically do not earth. There is one plastic connector inside a plastic box on the light, with three connections, only the outer two being used. Do I just combine the current two live and two neutral connecting them both to their respective connections and what do I do with the existing earth wire. Any help appreciated, not an electrician, but it seems silly to get one out if it turns out to be very simple.
Wife will also be changing ceiling light, thankfully not bought anything yet as that has six bulbs. I may need to surrender at that stage.
