I can spell electricty and connect same colored wires to connections, but that's about it.
My old water heater has the attached sticker on it-see picture.
I want to replace with the one linked below.
My issue is the watt differences.
Should I be able to simply disconnect electric and connect to new unit (other than plumbing, which is simple.).
https://www.lowes.com/pd/A-O-Smith-...uble-Element-Electric-Water-Heater/1000216809
Thanks so much in advance.
They are similar in specs.
If you are unsure then get a local electrician to advise and install.
Morrow County, Ohio
United States of America
Replacing water heater
DIY Electrical Advice
Thread Tags
Tags Tags
None
MountGileadVillageIdiot,
James,
