Requirement to Change Tails? | on ElectriciansForums
Discuss Requirement to Change Tails? in the UK Electrical Forum area at ElectriciansForums.net
P
Piratepete
Met a (proper so he said) electrician in my local Denmans. In a discussion about changing a CU he said I needed to put new tails in. I said 'wot even if they're the correct size and in good condition?' He says yes!
That's new to me! Anyone?
Pete
Pete
Just another plank that's repeating what he has heard without questioning it.
He is absolutely correct.
Whenever I change a socket I always replace the wiring to it.
It's the same with light fittings, rewire the lighting circuit every time without fail.
:speechless:
generally you need to replace the tails because the old ones are red/black. that will never do. what if a french electrician was the next man there. he'd hold up his hands in horror. oh, seems they did that in 1940.
It always puzzles me this. The OSG tells us to replace the tails for 25mm regardless. I have mentioned this to one or two Network guys when they have been at a premises fitting an isolator, while cadging seals. Most domestic supply cables are 16mm, so putting a 25mm tail in "in case the cut-out is upgraded in future" seems a bit daft to me, and they have all, to a man, agreed. This has been irrespective of if a few seals have fallen out of their pocket as they got into the van.........I suppose there must be a logical reason for it?
Does the OSG actually tell you that? I don't think so.
Reply to Requirement to Change Tails? in the UK Electrical Forum area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Hi everyone, Quick background. 37, Employed Full Time working offshore in a mechanical role (zero electrical skills needed). Self funded and...
