E
eskimo39
Been on a nightmare of a job today where every hole I drilled for backboxes etc just opened up too much to hold plug firmly. Back there Monday so have just had a look online at the Fischer Polyester Styrine free resin. The tube, 10 spare nozzels (it dries quickly) and the pump for cleaning out holes comes to ÂŁ30 which I am more than willing to pay if it works.
Has anyone used this or anything similar for such a lightweight fixing???
I used it in the past for fitting stud bolts when installing some heavy duty CU's where you just drill the hole, blow it clean, inject the resin and then push in the bolt.
My plan is to go around firstly blowing out all the holes, and then add some resin to each hole immediatly pushing a plug into it whilst still soft and then leaving it to go off. Will this work????
Also on a different subject (just had a conversation today with a chippy) does anyone on here use an impact driver for putting screws into rawlplugs???? I thought they were just for screwing into wood and would destroy a plug!
