Resin joint on well pump | Page 2 | on ElectriciansForums
Discuss Resin joint on well pump in the UK Electrical Forum area at ElectriciansForums.net
Ireland
Hi all. I'm fitting a resin joint on a well pump flex so the joint will be left in a vertical position and probably submerged ?
How long after making the joint could I safely lower the pump down ?thanks
Im used to joints on the flat in trenches so wasn't sure on this one thanks again
What kind of pump is it OP?
Something like this?
No nothing like that
Dunno the term
It fits down something like an 8" diameter well pipe
It's cylindrical shape stainless steel finish
It's a borehole pump. The top half is the motor, and they are usually filled with oil to keep out water, using the principle of the diving bell.
They soon overheat if the motor isn't in water.
Sure the hole is a big as 8". The one's I've fitted go down a 4" pipe.
Can't recall now could be 4 or 6
Thanks again , borehole pump sounds about right
Readings were low , unsure if it was waterogged or ran dry.Unfortunately I didn't get to see pump
Reply to Resin joint on well pump in the UK Electrical Forum area at ElectriciansForums.net
I have an "old school" electricity monitor similar to this one...
