Karin
afternoon all, been reading up on testing and just wondering about the different types of testers and how they work..
insulation resistance - creates a potential difference across two conductors and measures leakage current to calculate resistance in MegOhms?
low resistance ohmmeter - i've read that these need to be capable of suppling a no load voltage of 4-24V and a short circuit current of no less than 200mA. does this mean that they work in effectively the same way as an IR tester, dropping a known voltage across a resistive item and calculating resistance from current flow? and is the short circuit current limit a requirement to ensure there is low enough resistance to guarantee accuracy?
guess i wanna know if they essentially function in the same way but on different scales?
loop impedence testers - these "circulate a current line to earth". does this mean that they create a link line to earth of suitable resistance to allow a, say 20A for high current test, current to flow and use that resistance to calculate the overall resistance (impedence) in the loop?
now i've started this electrics thing i'm starting to think i should have done some studies in electromechanical engineering 'cause i just wanna know everything! or maybe it's just a slow sunday and i'm waiting for the ale to kick in..
cheers!
cheers!
