C
chris013
If you were to retest jobs that had been tested 5 years previously would you expect Ze to be lower or higher .RCD times to be lower or higher .Thanks Chris
Discuss Retesting previous work in the UK Electrical Forum area at ElectriciansForums.net
i could use my fluke for the continuity tests as it has been calibrated so it would comply
But does it produce the 200mA test current?
This is the line I was thinking along. I checked the reg and it is only recommended however and not required.
But why would you not follow such a sensible recommendation?
and i think you will find that you dont need an instrument calibrator to calibrate instruments.I think you will find that an instrument calibrator is quite a specific (and costly) instrument. It is not just an ordinary multimeter.
your cheap crappy bnq multimeter shouldnt be used i agreeAsk Shanky I suppose. I have always been taught "a multimeter cannot and must not be used for any recorded test results" and that's the way I still work.
Reply to Retesting previous work in the UK Electrical Forum area at ElectriciansForums.net
