reverse polarity on appliance socket | on ElectriciansForums
Discuss reverse polarity on appliance socket in the UK Electrical Forum area at ElectriciansForums.net
london
Carried out an eicr and noticed x2 double sockets have reverse polarity that supply a frying machine at high level.
After correcting the reverse polarity on the two sockets i plugged the fryer back in and the circuit MCB tripped out and the appliance popped.
I am unable to open the fryer up as its fixed into the unit.
I cant seem to work out why the original appliances required the sockets to have incorrect polarity at the socket, and after correcting the reverse polarity the appliance tripped the fuse.
I checked the newly configured polarity and the sockets were correctly wired wheres before the L-N had been reversed.
After correcting the reverse polarity on the two sockets i plugged the fryer back in and the circuit tripped out and the appliance popped.
What tripped CB,RCBO or RCD what instrument did you use to confirm correct polarity? looks like you need to carry out some more test on the circuit supplying the 2 twin sockets
Without the fryer plugged in the MCB stays on, i checked the plug top and it was fine.
Fault on the fryer then, diagnosing from afar. As the job was an EICR thats, an inspection of the fixed wiring, which you have found and rectified a fault, your client needs to get the fryer tested under ISITEE the new way of saying PATesting, in my opinion.
Reply to reverse polarity on appliance socket in the UK Electrical Forum area at ElectriciansForums.net
Im not as clever as you guys. I would be doing what somw others have said, I would be leaving certain items switched off for a period of time...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
