View the thread, titled "Reverse polarity on pressure mat" which is posted in UK Electrical Forum on Electricians Forums.
I have this PM156 pressure mat 25V/0.25A and I want to make it operate a low voltage light by switching off the light when pressure applied, I will need to reverse the polarity, does anyone have any ideas?
The connections are a normally open switch and a tamper loop, so a simple circuit with a power supply and a lamp would make the lamp light when pressure applied, not switch off when pressure applied.
You can use a normally closed relay to get what you require, or a simple transistor switch, or, if the light is a LED supplied by a series resistance, you can extinguish the LED by connecting the switch directly across it and shorting it out.
Reply to the thread, titled "Reverse polarity on pressure mat" which is posted in UK Electrical Forum on Electricians Forums.
