A
AloysiusParker
Hi all,
First of all, sorry if this is the wrong forum to post this question in, it seems i'm not allowed to post in the DIY forum.
Some context if needed: I am a non-technical student and I’m currently doing research on respiratory variations in coronary blood pressure traces. These coronary blood pressure traces are registered by a console, but there is no inbuilt option to register the respiration of course. Therefore I would like to convert the respiratory cycle into a pressure signal and measure this simultaneously with the heart blood pressure traces registered by the console. I would like to do this by modifying a disposable pressure transducer so the pressure sensor is built into a mask and the connector fits the consoles input requirements; this is a high-level (+- 5 volts maximum), ¼-inch phone jack input meant for mean central venous pressure, but is never used during standard procedure.
The pressure transducer has a 5 pin output:
Red: plus excitation
Grn: plus signal
Wht: minus signal
Blk: minus excitation
Ylw: ?, not specified in the specifications.
So, what I’m trying to do in a nut shell, if even possible, is to convert the pressure transducers 5 pin output into a ¼ inch audio jack. I'm not technically gifted, nor learned, and therefore I am in need of some help on this matter. It would be very much appreciated.
I wanted to consult you guys before ‘experimenting’ with electrical equipment.
My first thought was to connect both excitation wires to the sleeve probe and the plus signal to the tip probe and the negative signal to the ring probe. What do are you thought on this? I’m afraid this is going to be a bit more difficult than I had anticipated.
Kind regards,
Henk
Grn: plus signal
Wht: minus signal
Kind regards,
Henk
