Rewire house using existing cable runs? | on ElectriciansForums
Discuss Rewire house using existing cable runs? in the UK Electrical Forum area at ElectriciansForums.net
When rewiring a house is it necessary for electricians to chase walls and ceilings, can't they existing cables runs to pull new cables through?
If the existing cables are in conduit etc then there is no reason why not, providing the new cables are within the approved zones.
It's not as simple as that. Floorboards will almost definitely need to come up. New chases are very likely even if they are in the same place (as very, very few cables are in conduit) as you cant pull cables through plaster. A rewire usually causes lots of mess and lots of disruption. Best to move out and come back a week or 2 later to a lovely clean house when it's finished, albeit full of chases to fill!
when chasing walls for cable runs I always put in flat plastic conduit when possible so as to allow changes later on. doesn't really cost more and costumers are happy with it when I explain that it could avoid chasing walls again in the future.
The sparks in fifty years time will thank you for that; thats if electrickery flows in cables then :)
This side of the pond we use conduit tracked into the walls. Will it be any use if you are rewiring a house? Unlikely right now as unless it was a horror install the electrical installation will be from the 80's (at best) or much older. In which case the location and number of socket outlets will not really be suitable for modern living.
Lighting is a bit different, if they aren't going full refurb and changing the doors and keeping them hinged as they are then conduit drops could be reused, but if an older installation then back box would need replaced (have come across round conduit boxes, wooden "backboxes", no backboxes, plastic back boxes, and in some of the more recent rewires silly 16mm depth 1 gang back boxes.
You obviously haven't done that many Social Housing rewires Mate lots of switch drops done in split metal conduits, as well as Sockets, difficult to rewire but not impossible if you know what you are about, something they don't teach, only experience will provide that skill set.
Once found this on a rewire, Pete. Innovative or what?
[ElectriciansForums.net] Rewire house using existing cable runs?
Reply to Rewire house using existing cable runs? in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
See there is the problem. I can put back to way it was. Is it safe, in my opinion NO!! It's wasn't safe before the incident. No Fused Spur...
