Rewire house using existing cable runs? | Page 2 | on ElectriciansForums
Discuss Rewire house using existing cable runs? in the UK Electrical Forum area at ElectriciansForums.net
How many costumers have you chased lately?
is that film costumers or TV costumers. i know they get a mention in the credits after the show, just before the make-up artists, but after the chief electrician (gaffer).
Years back with my Uncle we had to rewire 1920's flat in Barons Court, parquet flooring, chandeliers and concrete thank god no additional lights or sockets so managed to use the old cables as draw wires through the embedded conduit in the walls and floors.
Used to do a lot of rewires. If done correctly in the first place you can generally pull though switch/ socket drops, even if it's been originally installed in capping. If your careful and keep your cables nice and flat you can have a fairly high success rate especially if you the electrician has a sensible helper that can pull and push the other end. ( not hang off it)
You get the odd drop where the capping or tube is cut a bit short of the ceiling or box but you can chop up or down a couple of inches if need be, you can slice wall paper and fold it back once filled sometimes too.
The old split conduit is always nice to see on a rewire. As long as the person doing the rewire has good experience and knows how to 3 plate lighting you shouldn't have to much of an issue.
Would fancy re-wiring a new build in 50 years though. A lot of house slashers don't use any capping or tube now days it's all about price.
Reply to Rewire house using existing cable runs? in the UK Electrical Forum area at ElectriciansForums.net
In Theory that’s a good argument but if you will be adding or moving switches or sockets or adding lights you’ll more than likely end up needing a...
See there is the problem. I can put back to way it was. Is it safe, in my opinion NO!! It's wasn't safe before the incident. No Fused Spur...
