Rewire Problem | Page 2 | on ElectriciansForums
Discuss Rewire Problem in the UK Electrical Forum area at ElectriciansForums.net
B
Ben Lewis
Good Morning,
I currently have a Honeywell ST699 heating and hot water programmer which I am looking to replace with the Drayton MiGenie.
However I'm having a few issues with it not working and since the swap over cannot get any hot water or central heating (severely in the dog house at home now!)
Could someone please assist with putting this right as I'm currently stumped.
Thanks in advance
That was not a neutral, it was a switched line coloured blue! I agree it is unlikely to be W-plan. To completely clarify, it would be necessary to understand what type of motorised valve(s) you have and how they are wired. Nonetheless, if you are 100% confident about which wire came from which terminal in the old unit, it is possible simply to transfer them to the correct terminals in the new. The difference between the two is that the common contact of the CH and HW relays is internally connected to Line in the MiGenie, whereas there were separate terminals (5 & 8) in the Honeywell that had to be linked with wires in the terminals. And of course the terminal numbers are different, they map as follows:
Honeywell (H) -> MiGenie (M)
H3 -> M4
H4 -> M2
H5 n/a
H6 -> M3
H7 -> M1
H8 n/a
If you are not sure which came from where, then you have a much bigger challenge as they will have to be traced out electrically.
H3 -> M4
H4 -> M2
H5 n/a
H6 -> M3
H7 -> M1
H8 n/a
Thank you very much, I do however have nothing wired in H4 so can't put it in M2 unless you meant I need to link live in to M2 ?
If there was no wire in H4 (CH off) then that strongly suggests that the system is a conventional Y-Plan with a mid-position 3-port valve. Correspondingly, there should be no wire in M2. If that blue was just floating about before, it should be made electrically safe as the situation at its other end isn't known.
It would, however given that the common terminals of the old controller were linked to line, it should be a straight swap. As I mentioned, if there is any doubt about the identity of the conductors, it's a different ball game, and it would probably be wise to call in an expert.
I am confident now it's a Y-Plan system as I have a Y-Plan 3 position diverter valve. I also know all the wiring colours for the pump and immersion thermostat so maybe better off requiring it from the start. Thanks again for your help.
me too.love a challenge. every morning i challenge my legs to get out of my pit.so far .i'm winning, but the legs are gaining ground. i hate being old. a teenage tearaway trapped in a 70 year old body., still could be worse.
Reply to Rewire Problem in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
