H
Hawk
Had a quick look at a property, which a friend has bought, to see what the electrics are like. From just doing a visual and from information from the previous owner, the property is late 60's early 70's and had additional works carried out in the 80's. My initial thoughts are that it will need rewired due to the age of the installation. However I will know better when I do a thorough inspection and tests. I have attached a picture of the fuse boxes/wiring.
What would your thoughts be from the info and picture. Would you rewire, due to age, even if the tests prove the wiring is ok?
