Rewiring christmaslights
Hello,
I have christmaslights with 7 preprogrammed cycles. I only need the last one, which is the solid light but to get to this I have to push it 7 times every day because there is no memory. It uses 24v. Is their a way to just connect the wires to get the solid light?
Unfortunately the program that runs the lights is embedded in that chip. It will just sit there monitoring the switch input and switching the relevant outputs on and off accordingly.
Very frustrating and annoying though.
vat he sed^^^^. you have a a.c. input and seems like a d.c. variable output.pusled/constant/whatever. it could be done, but not worth the hassle. buy some different lights.
I’m not saying “do this” but what does anyone think?
There looks to me like there’s 4 circuits going out to strings of lights with a common return path (1,2,3,4 and C on the circuit board)
Would linking the 4 strings together cause them to all be in together whatever program is selected? (1+2+3+4) leaving C as return?
Or would doing that blow the chip and several other components?
Surely if you connect them all together then they would all be on together?
The large red capacitors and power resistors suggests these are mains lights though not 24V?
Possibly so. Could be a capacitive dropper to lower the mains voltage for the control circuit.
OP, does the supply input wire go straight to a mains plug, or is there a power supply/transformer?
Which is exactly how the OP wants them to work...
Freddo, we don’t know for sure just taking op’s word it’s 24v. I assume there’s a plug in adaptor.
I think it’s quite an old set of lights looking at the size of components.
Good point, I must learn to read posts correctly. That makes things easier then!
At a vague guess, the input to this box is 24V AC from a transformer (input cable is not rated for 230V). Then there are four circuits, possibly some DC voltage out to LEDs around 24V, with the four power devices, driven from the control IC?
I'd guess you need to keep the four separate power devices, if you tried to drive all the lights from one, it would blow. So look at these devices and find out what they are and what is needed to make them give the continuous "lamps on" state. Presumably just some DC voltage. Then cut out the control IC and feed them with that.
Disclaimer: I accept no liability if doing this destroys the lights or the control box!
it might be that the 4 outputs each serve all the lights. 1 for constant, 1 for flashing, 1 for sequencing. etc. if so he needs to know which does what and mod the connections accordingly.
I'd have thought each output would be for one colour in the string. Not certain though. Would be worth a bit of experimenting to confirm.
The first two answers given are almost certainly correct - the patterns are pre-programmed into the dedicated chip and can't be changed. The four driver transistors on the bottom end of the PCB will be driving LED groups on the output string, but the sequence is down to the embedded controller. Any changes the OP could make would just break the lights - none of the outputs will on their own force a pattern change embedded in the controller.
Buy new lights...
Buy new lights...
Yes, but he wants all lights to be permanently on, which should be possible.
Fristi,
stewartrossinv,
TrueNAS JBOD Storage Server
