rewiring | Page 3 | on ElectriciansForums
Discuss rewiring in the UK Electrical Forum area at ElectriciansForums.net
A
AJAY198887
Hi, I have just bought a ground floor massinette, and asked my electrician for an electrician certificate. He went into the property and opened a few sockets to have a look at the wiring behind. The wiring looks in extremely good condition but is only black and red separate single wires (not 2 wires in an outer casing). There is no earth wire. The sockets have a wooden box behind them instead of the more modern metal ones. My electrician has stated that I have to have the full rewiring redone in the whole flat. I just wanted to check if there was any way around having to get the full rewiring done as the massionette is fully decorated to a high spec.
Thanks in advance.
Steel conduit is a cpc so why would you add another one inside it?
I agree wooden boxes is a bit suspect, but saying that stranger things have been found, if it is indeen serviced by wooden boxes the conduit could not be used as the cpc as it wouldn't be continuous. But as others have inquired a picture and proof of the wooden box statement would put the debate to rest.
The conduit can still be used as the CPC as long a suitable flylead is connected. There were, and still are suitable conduit fittings for connecting a fly lead to a conduit.
I realise they weren't available in the past but these days I use the piranha nuts on the end of steel conduit if I'm running it in to an insulated enclosure .
Sorry Dave you are saying that if the conduit is not connected into the box (if it's wooden) then use a connection via a flying lead connected to the conduit, that would be a tad difficult with the tube being buried in the plaster, don't you think? good idea though.
Also, you would need to know if there is a CPC serving the length of the ring final circuit, which as there's no earth conductor and wooden boxes I would highly doubt it. Again though, this needs to be ascertained through the correct test procedures.
It's in steel conduit, therefore there must be a cpc at every point already
I do know without seeing it, but there are a few different ways. There is such a thing as a coupler with a terminal fixed to the outside which is used to connect a flylead to the conduit.
You've told me that because it's in a steel conduit it must have a CPC at every point. Then you've told ne, when I asked how continuity was achieved that you don't know without seeing it.
So which is it?
Battle of the Dave sparks, who will win, only one way to find out....FIIIIIIIGGGGGHHHHTTTT:handfist::handfist::handfist::handfist::handfist:
Reply to rewiring in the UK Electrical Forum area at ElectriciansForums.net
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
