If installing a hybrid heat pump would there be a charge for the heat meter to be fitted and if so would this be a yearly or one off payment.
The heat meter is part of the installation and would normally be owned and read by the owner of the installation. Whoever installs the heat pump would normally install the heat meter if one was required. There is no requirement in the RHI rules to contract with a third party to read the meter for you.
There is an extra 250 pounds for heat meter per year. If customer wants one,optional yes. 3rd party installer will install the meter. There is a list of preferred installers. But I am installing hybrid heat pump, so one is required. Not sure about costs thou.
Hi Jason
Where did you get the £250 annual charge from ?
Have you been able to get quotes for the M&MSP's? If so who from?
As I understand it, although in a hybrid situation metering is compulsory, the M&MSP's are not compulsory, unless you want to have the additional payment from the Govt as part of your RHI payments to help them with their monitoring. - Maybe I misread that?
A decent heat meter costs about £450.
In a hybrid heat pump situation you need a heat meter and an electricity meter (for the power to the heat pump)
We've got three hybrids on the go at the moment :).
As I understand it, if you're not going for the extra payment, there is then no requirement for a specialist meter installer as long as you are 'competent'.
Renewable Heat Incentive
to help improve performance of renewable heating systems, there will be an extra incentive for applicants who install metering and monitoring service packages, of £230 per year for heat pumps and £200 per year for biomass boilers
sorry thought is £250
Yep, so it's the EXTRA payment you are going for... Looks mighty convoluted to me - we simply included the cost of the meter in the quotes.
We break our quotes down as per the RECC guidelines now as there are so many elements and then the customer understands what we have to do.
The details on what YOU have to do to offer the M&MSP to your clients was published in the consultation documents - I've attached it, because it seems to have been pulled from the MCS website (because the consultation is no longer open) :
View attachment MCS Domestic RHI Metering Guidance Document - Draft for Comment__.pdf
Get this too: RHPP2 Installer checklist with trained installers (PDF) / PDFs / Generating energy / Media - Energy Saving Trust England
From the EST's website The Renewable Heat Premium Payment phase 2 - Generate your own energy - Energy Saving Trust
So I guess you need to use one of these guys to install the meters etc - the MCS document above refers to subcontracting this service to them..
It is a condition of the grant that you participate fully with the survey and metering programmes. Refusal to do so will result in your grant being withdrawn or reclaimed.
A number of MCS installers have attended training events organised by BRE on the technical metering requirements of the RHPP2 scheme and have signed sub-contracts with BRE which enable them to install monitoring equipment at appropriate sites under the scheme. These firms are listed below:
A.P. Chant Building Services
Aaron Services Ltd
ACS Renewable Solutions Ltd
Alex Murray Construction Ltd
AOS Solar Energy
Baystar Energy Efficient Systems
Black Isle Renewables Ltd
Blue Flame (Cornwall) Limited
British Gas Trading t/a Cool Planet
Correct Contract Services Ltd (CCS)
Dalliam Ltd
Ecoliving
Ecotec Services Ltd
Egeenergy
EON UK PLC / WorldHeat&Power
Finn Geotherm UK Ltd
Gas World
Glevum Heating
Global Energy Systems & Technology Ltd t/a Global
Ground Heat Installations Ltd
Heacol Ltd
Husky Heat Pumps
Ice Energy Heat Pumps Limited
ISO Energy Ltd
Lakehouse/KT Heating
Mark Group
Neil Shacklock Plumbing & Heating Contractors Limited
PA Carruthers Ltd
Paynes Heating and Plumbing Services Ltd
Redmond Group (Yorkshire) Ltd
Renewable Solutions UK
Renuvo Limited
RES Devon Ltd
Source Energy Ltd
SSE Home Services Ltd
Thermal Earth Ltd
TSG Building Services plc
Verten Limited
WDS Green Energy Ltd
I read somewhere that hybrids must have a meter installed. I have not mention to the customer about the extra payment , just in case Hybrids don't qualify. I need information if there is a fix cost to install and yearly fees.
They have to have a meter, you can install it, the customer reads it, just like a generation meter.
No metering charges.
The metering is quite straightforward - assuming we are talking about monobloc heat pump with a single outlet (that then splits Y-Plan to DHW / Heating)
You need an electrical meter to measure the consumption of the Heatpump (Use the same meter as the generation meters installed the correct way round :) ) and a heat meter to measure the heat produced. - My drawing above is exactly the one to follow.
Speak to Chris at these guys: DMS Ltd, We are Heat Meter Suppliers in the UK. We Offer a Wide Range of Different Suppliers All Across Europe - DMS Limited offers a wide range of products.
The SC 539, is a good price, and does the job, can cope with Glycol too if needed :)
The guidelines are here:
https://www.electriciansforums.net/..._domest_renewable_heat_incentive_-pdf.120438/
(From here: https://www.gov.uk/government/consultations/renewable-heat-incentive-proposals-for-a-domestic-scheme )
here:
and here:
pm me / call me if you need more info, it's quite simple once you get your head around it - oh - 99.99% of plumbers can't :)
G
garyevans
G
L
LostinFrance
L
Lincolnshire
RHI Metering
Thread Tags
Tags Tags
metering
jason121,
Worcester,
