Rhi | on ElectriciansForums
Rhi
Discuss Rhi in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Lincolnshire
Submitted my application today for heat pump. Very straight forward to do. Not happy about the fixed SPF on heat pumps installed before April. Anyone else applied yet
I thought the fixed SPF of 2.5 for HPs installed before the domestic rhi scheme launched was a default, but you were able to submit evidence that your installation achieved better?
Didn't know there were going to stagger the dates. No i didn't apply for the funding I am on mains gas. I was surprised about the figures used are all from the EPC issued by the GDA's.
That's been a topic of debate for quite a while as we see a difference between assesment and actual of between 30% and 50% (actual useage being greater) so we advise customers to consider it as effectively a discounted rate.. Also it helps to work with Energay Assesosrs / GDA's that are aware of the reasons for the reports. Also we've seen significant variances between those when an EPC is produced for the sale of a property and the figures when assessed for the GDAR.
It is what it is and DECC won't change it, so it's a case of living with it.
Reply to Rhi in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Installers must examine the energy device and required connection to determine whether the Distribution Network Operator needs to be informed...
Update. Went back today as it was popping the other RCD post move, again intermittently with no real pattern. Typically overnight but not every...
