mrloy99
- Joined
- Dec 21, 2008
- Messages
- 473
- Reaction score
- 18
I have just recently started a new job-its a nursing home and I have been giving the work of 1st & 2nd fix to the 60 odd ensuite rooms.The job is on 2 floors and there is only one dist board on each floor.I have been instructed by the foreman to wire one ring(and one lighting circuit) to do a clump of 4 bedrooms.The first two we wired used 45m of 2.5 not including the leg back to the board which is an additional 43m.So by the time this first clump of 4 is finished we will have used around 200m for the ring.Some of the rooms are further away and will take around 250m.The circuit is to be protected by an 30ma rcbo.
It seems to me an awefull waste of cable and I would have thought submains were the way to go.The foreman says that there is to be very little load as the residents are to be old folks.I dont think the on site guide covers this installation as its not domestic and was wondering if any of you learn'd bretheren out there have any views on whether this installation would comply with regulations.The cables are to be installed on basket in the corridors and clipped to bison units in the rooms and I would imagine there will be sound proofing insulation in the studs between rooms.
