I came across a fault on a RFC, no continuity on r1 and rn. I had continuity on r2. The work was part of a bathroom refurbishment, where a socket was in part of the extended room. I had to move the socket to and adjacent wall to make it accessible. Discovered the fault before moving it. OCPD is 32amp mcb.
I had a similar fault once before, informed the customer and made a note on the cert. As I don't do EICR's, I just wonder what terminology you guys use. I have said that 'this fault is potentially dangerous and warrants further investigation'. Is that correct terminology, or would you describe it differently?
