Ring Continuity fault on RFC | Page 2 | on ElectriciansForums
Discuss Ring Continuity fault on RFC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Good luck finding the results from the CU change.
Barry from down the pub probably did that one
Yep, strip connectors, tails buried in wall, swa to car charger wid no gland, were just a few things I spotted.
Where the tails existing or have they been installed when the new cu was fitted?
Well, looks like the property had an extension. So previously the meter box was on the outside wall, and I suspect the old CU was in the garage. This has now been converted into playroom and a kitchen diner. So the plastic meter box has gone, wooden meter box (I carp you not), tails horizontal across wall in plastic trunking at waist height, then disappear to be revealed at CU at ceiling height.
Edit; I suspect some builders involvement :)
Reply to Ring Continuity fault on RFC in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Very technical :D
Often, but not always: 543.2.9 Except where the circuit protective conductor is formed by a metal covering or enclosure containing all of the...
