Ring doorbell Pro installation help | Page 2 | on ElectriciansForums
Discuss Ring doorbell Pro installation help in the UK Electrical Forum area at ElectriciansForums.net
Southampton
Hi, does anyone on here have any experience wiring a Ring doorbell Pro from scratch? All the information provided by ring is if you were replacing an existing doorbell installation. Contacted Ring but they were less then helpful
If you buy the version with the chime, it comes with a transformer too. You need to put this in a suitable enclosure (e.g. ESE2) and supply from a suitable source (e.g. 3A SFCU) if you don't have an existing bell transformer that does 24V (unlikely, most are about 8V). Bell wire from the transformer to the doorbell.
Once power is applied, set up the app on the customer's phone (they will need to register etc). The doorbell generates its own wifi network, the phone (via the app) connects to this, the two are paired, the app then tells the doorbell about the house wifi (gives it the house wifi password), doorbell and phone then switch to using that.
Plug in chime. Tell app you have a chime. It should find it (again, the chime generates its own wifi network which the phone app links to, then tells the chime about the house wifi, then they both switch to that).
A right faff, particularly when you get to the point of installing the chime and it fails to light up or in fact do anything, and you end up talking to Chuck in the USA for half an hour while they sort out shipping a replacement so you don't have to uninstall the doorbell and transformer and get the customer to return them to John Lewis.
I always, always do these jobs on a "by the hour" basis as you never know what little gremlins of joy you're going to discover. :)
Reply to Ring doorbell Pro installation help in the UK Electrical Forum area at ElectriciansForums.net
Hi, How did you install your doorbell in the end?
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
