Ring fault | on ElectriciansForums
Discuss Ring fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
daiplayer
This one baffled me
Complete ring continuity on each conductor L-L ,N-N,E-E
IR - N-E : 0.00 Mohm @ 500 Vdc
split ring in middle - 50.3 Mohm on one side of ring
- 30.2 Mohm on other side !!!!!
the fault disapears on both sides when i split it ! HUH ???????
Reinstate full ring and faults reapears : ?????
what were your step one results LL NN EE
What were your step 2 results L1N2 L2N1 cross connections
What were your Step 3 results L1CPC2 L2CPC1 cross connections
Make sure these results are correct before IR testing
It Sounds like a neutral earth reversal somewhere
release all sockets and check connections at rear
Last resort remove all sockets seperate all cables test each piece of cable in turn
bet there is a junction box or socket you have missed which has the fault connected to some thing like a garage supply off the ring main and an external light full of water connected to a garage supply some where between the position where you have split the ring is a connection you have missed
hi there. i bet you will find that if you take the sockets off , and perform an I.R test on the sockets themselves you will find some of them down. if not there maybe dampness causing this , or you may not of unplugged everthing in the property ie an extension lead under a kitchen cupboard. hope this helps
good point tomo had this 2 or 3 times 2 cats had pee'd over a socket and one embarressed 23 year old slightly bevvied up had also done the same
LOL i have tested properties for over 19yrs every single bloody boring day. Nothing still seems to amaze me, you will never stop learning you will always get better. p.s a problem shared is a problem halved...
Reply to Ring fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
