Ring final circuit vs Radial final circuit | Page 6 | on ElectriciansForums
Discuss Ring final circuit vs Radial final circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm a big fan of the ring circuit in general but I would be in favour of outlawing the ring final circuit in domestic installations
Reason being that it's not a necessity and it would prevent hazardous situations such as breaks in the ring and overcurrent on spurs
still useful in a kitchen though. where the load would require a 4.0mm radial.
But if you get a break in the CPC in a ring circuit, at least you still have a CPC present.
Pros and cons of both circuits really.
You have hit the jackpot there TEL. Run a 4mm radial instead of a ring circuit. Let's see... get rid of the two 2.5mm,s.Replace with a 4mm.Thats a, saving of 1mm of copper per circuit. Think of the benefits for "the environment" ?
Reply to Ring final circuit vs Radial final circuit in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Who knows? There's this, in the OSG app H: "Permanently connected equipment should be locally protected by a fuse complying with BS 1362 of...
I thought I'd add a few photo's of the overall situation we find ourselves in and the general standard of the building work, which is why going...
