Ring final end to end test | on ElectriciansForums
Discuss Ring final end to end test in the UK Electrical Forum area at ElectriciansForums.net
M
Maxstone89
As doing a cu change ,I have a ring final in a house with an end to end reading on r1-r2-Rn are so low that somewhere very close under a floorboard the ring must have been connected together somewhere, customer refused to pay more, so i have put in a 20amp mcb. To comply with current rating of a 2.5mm cable for a radial circuit,
What would you have done.
Regards Kurtis Randle
Did you test to see if the there was a bridge connection anywhere?
It was end of day and they didn't want to pay for anymore, just said make it safe, i had briefly done some tests but didn't have much time, so guessing it was in a junction box. Is changing to a 20a mcb okay. Its safer than before i know that
I think you made a good call. Personally I think testing and verifying RFC's which are an unknown quantity is often very difficult within a reasonable timeframe and without excessive disruption. Verifying spurs from spurs etc and inconsistent continuity readings may well be beyond the scope of what it is reasonable to carry out for a CU change.Note on your EIC that the ring requires further testing because of unexpected readings and that until the ring is properly verified the rating of the OCPD has been reduced to ensure safe operation. --- covered.
Agree, as if the customer wont pay all that can be done is to make as safe as poss in timeframe and cover --- in EIC by noting it down and inform customer.
Was the testing carried out prior to the CU change?
Is this an old house, e.g. 1960's? Sometimes the RFC is wired so all the socket drops are spurs from junction boxes (under floor or in ceiling) connected off what is then electrically quite a short ring. Then for a single floor, r1=0.14 could be quite a reasonable value.
Reply to Ring final end to end test in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
Interesting question & always gonna get different views on this. EICR testing seems to have changed over the years & not by us the Electricians...
