ring main advice (fused connection units) | on ElectriciansForums
Discuss ring main advice (fused connection units) in the Australia area at ElectriciansForums.net
hi there
just been to a property too possibly extend a ring main (2 extra sockets). when looking at the ring circuit i noticed 2 fused connection units, on further inspection these were not spurred off the ring main but wired as part of the ring main (supply side) i assume they were once single sockets and have been replaced with fcu's for some reason.
is this still allowed as i have not come accross it before. appears to me to be electrically safe as it stands
any advice please
hi there
any advice please
Perfectly fine, it's better than a spur if you think about it!
Reply to ring main advice (fused connection units) in the Australia area at ElectriciansForums.net
Outside socket… ok. But you say the fcu for boiler is beside the outside socket… is the boiler outside too? FCU’s have an IN and an OUT… the OUT...
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
