Ring main help | on ElectriciansForums
Discuss Ring main help in the UK Electrical Forum area at ElectriciansForums.net
Mark.W
Swindon, Wilts
Hi
I was wondering if someone could give me some guidance on a ring main please?
The ring consists of 21 CCTV columns drawing 5A each. The total length of the ring will be 1600m.
Is there a calculation I can use to calculate correct cable size and breaker rating?
Many Thanks
Mark
you know the load so start with a cable that can handle that. then work out your csa from calculation. mV/A/m needs to be determined from Amps and length. then size cable accordingly.
Insulting behaviour reproted. Incidentally, if you don't know how to design a circuit then you're in the wrong job mate. Anyway, enjoy the rest of your time here because I suspect it won't be long
Thanks telectrix
I know how to do cable calcs but it's working out the ringmain. I know the rule of thumb of 100ft per circuit incorporating sockets etc etc but never installed a ringmain of this size! Can't find anything in regs book either?!?
Hi
Many Thanks
Mark
I tried to reply earlier but the thread was locked, apparently someone has been abusive or something?
The OCPD rating can be calculated the same as any other circuit, you work out Ib then select an appropriate OCPD. If it is a ringmain (distribution cct) you want then an HRC fuse might be a better idea than a circuit breaker.
Your cable size will almost certainly be dictated by the VD rather than the CCC of the cables. There is a formula in the regs somewhere for calculating the VD of a ring circuit.
Formula for VD on a ring is
mV/A/M x ib x L / 1000 / 4
Reply to Ring main help in the UK Electrical Forum area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
